Why anti virus Eset nod 32 hangs my computer?
Hi to all,
Unfortunately my system infected with virus badly especially it damaged my important data. So I installed Eset nod 32 antivirus and updated it quickly. Now real time protection status appears and every virus is cleaned up almost.
But every time I reboot the system, Eset nod 32 gives option “Explorer is accessing virus and requesting for another reboot”. Again rebooting also hangs computer with the same error and some time I have to use task manager to kill it. Please help me how to solve this problem.
Answered By 30 points N/A #168181
Hi Tysons Harpe,
First I would like to tell you about Eset Nod 32 antivirus.
When we install this antivirus then if you check it carefully then you will see that there is a driver which is installed during this installation process.
This driver is actually the launcher of the services of Eset antivirus.
This driver works just like other hardware drivers and relate to the same file.
And now this is happened that your computer was infected already. So the driver of Antivirus services is crashed out due to viruses.
So that your computer is started to hang up. You should uninstall this antivirus and choose another.
I hope you got your answer.
