zahangir07
Posted on - 09/18/2011
I know antivirus is one of the powerful software that can able to get an action upon virus. My question is why antivirus cannot perform or delete some data which is required for installing a software?
Drothy
Why Antivirus performance is not suitable for any device?
Hi!
As you are aware of the powerful functionality of the antivirus programs. These especially designed softwares do have their impact on the files required for installing a software. It is just a misconception about the antiviruses that they cannot perform deleted operation on such executable files even they can either delete the files if infected or they can fix them by making them read only. There are a number of antiviruses available which can scan your executable files besides your data and can perform deleted operation on all files regardless of their type and functionality.
Hope it answers your query.
Antivirus software is designed to safeguard computer from computer bugs, Trojan and files that destroys software. It's function is to let you know that their is a potential intruders or virus infections. To have this software installed in your computer, then you will have less worries that your computer might infected with these unwanted files. You might have important files and information saved in your computer that you don't want to share with anyone. And virus has the ability to steal this from you. You better need to have this type of software installed for computer protection.
During the installations, the computer must meet the requirements needed to install the software properly. Once finished, some files might be deleted because the software itself thinks that it's a threat, virus and or Trojan files stored.
This happens, although the antivirus software does not intent to delete the files but it has this executable files that auto-detect threats, delete and quarantined.
