Nelson Raun
Posted on - 03/29/2013
Hi to everyone. As antivirus is powerful program to save your data from different virus. Spyware etc. I have installed avira for this purpose but after installation it is blocking files containing .Exe like software setups, web page files. I have restarted computer but same problem. Please tell me what to do as it is creating big headache for me.
Why Antivirus Avira for window 7 is blocking .Exe files continuously?
Hello Nelson,
For this issue you can contact to the Avira support team but I don't think that is much of a use, in order to get rid of it, just Un-install it and install some other antivirus software like Avast Antivirus. I personally used this antivirus for years and there is no compatibility issues in windows 7. To get full version of Avast Antivirus you can check in their official website, here is the link : https://www.avast.com/en-in/index
Hope this will reduce your head ache.
Thanks!
