What is the use of Header and Footer in a document?
You can add headers and footers to a document from the View menu like View > Header and Footer.
Why are the functions of headers and footers in the document?
Headers and footers are used in MS Word to make it a pleasing appearance. A header and footer can be used to indicate page numbers or indicate the project name or the company name, etc. You can also use graphics and images when required in a header or footer.Â
Headers and footers need not be the same in all the pages of a document. For example, if you need the company name in the first page of the document and page numbers in the remaining pages, it can be done. Not limited to this, you may also include multiple headers and footers if you have different section in a particular page.
For complete information on the settings and effects of Header and Footer, you can refer the knowledge base article in Microsoft Support.
You can write Header on a save document of your computer. You can write Footer on a save file of your computer. What you wanted to write within your selected document should be saved previously. Maybe you have left something important to write in your document.
The Header should be written on the upper part of a document and the Footer you can write in the lower part of your document. After that you can copy and paste your Header and Footer into another file. Please try to think how you will be able to use your Header and Footer into your document.
