Why Artisteer latest version is not working properly?
Hi. Artisteer is most powerful web design tool but there is a little problem. I created the project as web templates using Artisteer version 3 and exported it to WordPress, but when I updated to artisteer latest version 4.1.0 then some images and contents of the project were not no longer visible. Now web templates look terrible without graphical image.Is there any solution to handle it?
Answered By 0 points N/A #149284
You can resolve this problem but you have to download this updated version from the trusted website. Download the full version with keygen then you will not face any problem. Just follow the instructions to install it properly.
1. Install the Artisteer setup.
2. Then after finish the installation, run the program.
3. Then you have to give Keygen to Activate.
4. Enjoy the Beta Full version.
Download from the following link.
http://www.artisteer.com/?p=news
I hope you may fix this issue.
