Why is avast blocking download?
I am trying to download file from internet, and it keeps telling me that avast blocking download. I know that file is clean and safe, so what should i do to get access?
Avast is blocking your download because the file is starting to download from an untrustworthy web page. The firewall security is blocking the download. You can go to "Settings" and remove the firewall protection in order to download the virtual content you seek. It is very easy to do, but this way your computer can get affected by virus easily. So please think what you are doing and how you should do it. You can ask me any questions you may have, if you want. You can do as I suggested, or you can uninstall the antivirus software.
