Hi. I am using avid studio for editing video and mounting different songs over album of pictures. Converting media files is easy task in it but I am facing studio crashes problems. When I add more music album and try to use them, avid studio stops working and shows crashing problem. Other features are working well. Please tell me how to solve this problem.
Why avid studio crashes while updating music album?
Hello Suzanne,
As you mentioned you are having hard time with AVID studio, the possible reason for this could be:
1. You are not installed most recent version of the AVID studio, if this is the reason just update AVID studio to latest version.
2. You should install all necessary windows updates, if you are using Windows.
3. This could also be possible that some files responsible for updating Media got corrupted and that giving you error, solution is try reinstalling latest version of AVID studio.
Hopefully these will resolve your issues.
Thank You.
