I am using windows 7 ultimate pre reactivated product in my laptop (Dell Vostro 1015). I wanted to make my laptop as a WiFi hotspot device that's why I download connectify.me software.When I run it to install its notify me that it will run better only windows 7 service pack 3. Then I activate windows update option and made to service pack 3. Then when I run that connectify.me program it appears a blue screen and system goes for restart. Every time when I try to run connectify its appears a blue screen then system go for automatically restart and it happens continuously until I setup a new copy of windows. I have tried several times to run and it happens same things until I setup new copy of windows on my laptop.
What was the problems, in my windows copy or in the connectify.me program
Why blue screen appears when tried to run connectify.me on Windows 7
Hello Prayashchakma,
You didn’t mention which version of connectify hotspot software is used you. Do you install registered windows 7 ultimate package? It is the problem for windows copy. You download connectify hotspot software for windows 7 ultimate and try it again. You can visit these below links for more details that helps you to solve your problem. The links are given below.
You can download connectify Hotspot from here free trial for checking.
1. Connectify Hotspot-The Wi-Fi software router for windows PCs
From this link you can know how to turn your laptop into a WiFi Hotspot and share internet with all your devices.
2. Connectify – Turn your PC into a WiFi Hotspot and get faster internet
From this link you will know how to turn your windows 7 laptop into a WiFi Hotspot with screenshot.
3. Connectify- Turning your windows 7 laptop into a WiFi Hotspot
You can also see this important video-
Please visit these links and get your solution.
Thanks
Taylor
