Hi everyone,
Please tell me what went wrong with Bluestacks app for windows 8.1. The main thing is I want to use Instagram via PC and I came to know that Bluestacks will allow me to use Instagram via PC but what I can see is Bluestacks just keep loading and then says no such app found "do you want to search web for this recipe?" Please answer this.
Why buestacks not showing instagram?
Hello Lawrence
Please check the following things
(a) Are you installing it on a Laptop, if so, it needs to be connected to a live power source during the time of installation.
(b) Is your graphics card compatible with Bluestacks, your graphics card should support Open GL IES 2.0, easier way than verifying this, is to update your graphics card drivers from the manufacturer's site.
(c) Do you have Bit Defender installed on your machine? If so, you have to choose between any one of them. Only one can be installed.
(d) Lastly, do you have VMware or MS Virtual PC or Virtual box installed as they are not recommended together with Bluestacks.
