Why can’t i play Cityville using iPad
How come we cannot play Facebook games (via Facebook app) on an iPad? I cannot play my Web City in Cityville when I access my Facebook account.
Hi friend,
I don’t know which iPod you are using. Normally in iPod you can access Facebook with iPod’s built in browser or any installed Facebook application but you cannot play Facebook games with it.
You need a better iPod to play Facebook games. Facebook games are flash games so you need to install Flash Player in the iPod. You also need Flash support in your iPod. In higher iPod versions Flash is a built in function for them. But not all iPod have Flash support.
If you have a smart phone with Flash support then you can play any Facebook games on it.
Hello David,
First of all do you have to have Adobe Flash player installed in your iPad, as this game needs an Adobe Flash Player. Though you will not be able to play this game directly on your iPad through Facebook you will have to download an application from the apps store. Once you download it, you can then login using your Facebook account.
Also you can download Splashtop Remote for your iPad and you'll be able to play Cityville, Farmville and many other games using it on your iPad. This is what one of my friend did last month when he came across the same problem. Hope this works for you too.
Best of Luck,
Thanks!!
