Why can’t I download anything on my computer
I am unable to download anything. A few days ago, my downloading stop I thought it is a temporary problem. But the problem does not resolve. Now I cannot download anything from the internet. As I think there is no problem with the internet as it is working well with other systems.
Answered By 0 points N/A #142643
You need to follow a different method to solve the problem. As different thinks can cause that problem.
Below is the method you can apply to solve the problem.
Go to the browser tool and then internet option after that advanced and then click on reset and check that problem is solve or not.
You need to restore your system to an earlier date before that the problem was established. You can do it by going into the setting. If the problem does not solve apply the following method.
Go to another computer download malarebyte and combofix and run them on your system and they will solve your problem.
