I have a 64 GB iPhone 5 LTE with the Apple A6 chipset and iOS 6.1.
Why can't I install AnonymousBrowser Pro in my iPhone 5 using app store?
The download bar just wouldn't go through the halfway mark.
I tried installing different apps and it finishes its download.
What could be the problem?
Why can’t I install anonymous browser pro in my Iphone
Hello good day to you,
I read about your problem regarding of the app that is not installing.Â
Maybe the problem is that your phone can’t support the application and the application needed more high specification or there is a problem about the installer you use maybe you tried other application.
I hope these opinions help to you.Â
Thank you.
Hello there Lutter,
You have the latest iPhone in your hand, hence I don't think compatibility of the app is a problem as Apple would definitely try to make every app of it compatible to their latest device. Moreover, even if it is not compatible it will open in the iPhone 4 mode with a small screen on your phone.
Hence, the problem I think is with the Apple servers rather than your phone or with the internet pack you are using. Try downloading it by connecting to a WiFi Internet, if it downloads then the error must have been with your internet connection. Else, it is with the Apple server hosting that app.
Cheers.
