Why can’t I watch videos on my computer. I open any website You Tube or any other website randomly if it contains the videos I am unable to watch them. The error that websites says that I should turn on the Java script or I should download the latest flash player. As I downloaded the latest version of the flash player and installed it properly, but again the same problem.
Please follow the procedure step by step to solve the problem. Open your browser and click on the tools. After the tools click on the internet option. Click on the security tab, then go to the custom tab. After all, you will see the Scripting section, click on the enable.
In some browser after clicking to the custom lever you will see different page.
* Java goes to the Java part you will see, the Java enable option under the Java Vm enable that option.
* JavaScript: GO to the active scripting part and then under the Scripting you will see two options then click on enable. And problem will be solved.
CHKDISK Error “insufficient disk space to recover lost data”
Question “ I have a large amount of data that have been deleted from my hard disk. I tried to recover the data by using the recovery softwares but the recovery procedure is completed. And it asks to run the CHKDISK to repair the damage files it runs, but after running the files it displayed an error that insufficient disk space to recover lost data. How can solve this problem to get my data back.
