Why cannot start mozilla firefox and Google chrome but i start ie
It’s as if your computer's internet connection is exclusive only to Microsoft Windows Internet Explorer and other browsers are blocked to connect. I know when installing Mozilla Firefox or Google Chrome it automatically detects the type of internet connection the computer has. So there is no need for you to manually configure it to the browser.
Check the connection settings of your Mozilla browser.
Check if Mozilla Firefox can now connect and browse the internet.
Hallo Andry,
I am trying to understand the extend of your problem with Firefox. Could it be that when you click on its icon it does not completely start or it starts but cannot browse where internet explorer can browse very well? Or could it be that it starts but crashes due to some error? I suggest you try the following:
It does not start completely, try rebooting your computer. The problem might go away just by restarting your computer.
If Firefox starts but cannot browse, ensure 'work offline' is unchecked. You can establish this by going to file in the Firefox main menu. Also check to ensure the proxy settings are properly configured by going to tools the settings.
If Firefox starts but crashes, I suggest that you uninstall and get a new version from the internet and install it.
Hope this helps.
Lee Hung.
