milodiaz
10 points
Posted on - 03/06/2012
I Installed Mac OS, and then Windows 7 on sed4. I also did this with Ubuntu and SWOP on sed5. But after installing Ubuntu, Window 7 could no longer loads.
Win boot displays the following message: “An error occurred while attempting to load boot configuration data.”
Should I try to repair Windows using CD installation or should I configure grub to make it work? What do you, guys, think? Thanks in advance.
Why can’t Windows 7 function with Ubuntu?
Dear,
I have read your problem and have best solution for you. You only need to know the basics of both the O.S (operating systems). You are trying san impossible thing to do. There is operating files system difference between the windows and Ubuntu.
I have given a link for you to give you a complete idea what I am talking about. Please visit this link,
https://askubuntu.com/questions/435160/cant-boot-windows-7-after-installing-ubuntu
I am sure after visiting the page you will come to know what Is possible between these both O.S. and what can’t.
Hope you got the answer.
Best of luck for your future.
