Why citrix is not opening by photon?
I want to test the Citrix ICA Client on QNX 6.3 with Photon. But Citrix is not opened by Photon. Please tell me Solution.
Citrix client ICA (Photon) is developed by the Chinese company Huawei. It's a good combination. There are quite a few products are available under the Wings of Huawei. The problem could belong to software versions. Kindly check it or update it ( if any new version is there). Or you can perform re-installing as well.
Now I am giving you a link where you can check and choose the correct version.
http://softwaretopic.informer.com/tata-photon-whiz-software-download/
Thanks
Although Citrix is a good solution that enables secure access to desktop applications and to data Motorola Phonton, you will encounter that Tata photon and Citrix are not working properly. Citrix plug-in has problems issues.Â
You can try to download Motorola Photon 4G for free from this site since this new freeware has new fixes for Citrix Access Gateway.
I hope this will help you.
