olivia.bha
70 points
Posted on - 03/23/2013
Hi. I have embedded some videos with css flash video slider but it is not working according to my expectation. Whenever a new tab opens in browser, video slider stops. By clicking the previous tab, it reloads and starts at the beginning. Even I tried to change browser but same result. Some guidance is required please.
Why css flash video slider stops as the new tab opens?
Hello, Olivia.bha
The main flash movie comes in 3 formats, the control player and its skin,, if needed both of them then come as SWF files. Embedding a SWF flash video is not difficult, the way is to just use the SWF object java script file which is called before the embedded SWF file that are encountered by the browser. Now the second way is to embed SWF flash video you have to use of Macromedia flash plug-in. If you are embed MP4 and FLV file videos, It is not possible to do only with SWF object. Here is the below link of the tutorial that how to embed swf, flv, mp4 files.
https://hubskills.com/embed-multiple-audio-clips-in-powerpoint/
Thanks,
Stella.
Hello ,
You can reload your webpage and see if you have no more problem. Clear your browser cache and reload webpage. Clear browser's cache and cookies before you restart your browser. The name of the error is error drawing fallback. No downloadable media found. This occurs when you setup solely on RTMP stream and then browse to your page or an iPad.
frijoe
Hello Oilvia, just retry to reload your page and just see if the bugs still exist if that still exists then try to restart your browser but prior to that make sure to clear your browser's cache and cookies and reload your webpage for several times. Commonly, this error exists when you set up the Real Time Messaging Protocol. This is what they named as the error Drawing FallBack. 🙂
