Why do i get partial list in ldap attributes Windows 2008?
I am getting partial list in ldap attributes Windows 2008 server.
Is this a problem?
Is there a way to fix this?
Is this a problem?
Good day Temptechy,
After a short research about your problem, my answer is this.
When you run a Lightweight directory Access Protocol or LDAP request against Windows Server 2008 – based domain controller, you obtain a partial attribute list. However, if you run the same LDAP query against it, you can obtain a full attribute list in the response.
This issue occurs when the Admin Approval Mode feature is enabled for the user account. It is also known as USER ACCOUNT CONTROL. The security system has a loop back code so it uses the active access token from the interactive logon session for the LDAP session and the access checks during the LDAP quest processing.
Hope this helps.
Thank you and god bless.
