Why do i have popup Windows zoom images error?
Is it something wrong with my display, because I keep seeing popup windows zoom images error? I heard it can harm my display, please someone explain what should I do.
Hello Toby,
If you are running an Internet Browser and you keep seeing this pop-problems. Then here is what you need to do.
One way to solve this problem is;
That should solve the problem. If not then here is what to do.
You should now be able to solve the problem. If errors persist. You might have a virus my friend, most of the pop ups has malicious links that throws viruses. If you happen to have clicked on it. Then there is a chance of virus inside your system.
If all steps fail. Scan your computer with your favorite antivirus and hope for the best that your software can detect and remove the viruses.
Else you need to reformat your computer.
Hope this helps you.
Hello there,
If you configured an Engage 09 interaction in a presentation as an image zooms in a new window than it usually shows “page cannot be found” error message during playback. To solve this problem download a file from this link.
http://articulate-ap09-kb.s3.amazonaws.com/flashcommand.zip
Extract the file and copy the flashcommand.js and paste that into the following URL.
X:Program FilesArticulatePresenterplayerscoreplayer
Now republish the image and configure it with your Engage 09 interactions. In the window you will get a checkbox which will allow you to zoom the image in the current window. Then click OK and the problem is solved.
Thank you,
Riley Weaver.
