I am getting script error when I am going to online. I have tried many times nothing takes care of it try to use different computer same web and the work fine no script error.
It's happening all the time when I go to online very annoying it is..: @
The site is uncertainly bothering me. I still want to run through a PC with this and I answer yes and I get it, but this has happened every time when I change page please anyone tell me hoe to fix it?
Why do i keep getting a script error message
First of all delete all shortcuts which exist on your desktop. Right click and click on folder and delete all the programmed, which is existing on the desktop. Delete all shortcuts. Then tick on start button click on programmed listing near on top this is should be two listing then one remove 64 sites on the side of the right click other on and click on the pin toward and sent to. Then recheck the web site which you have a problem with this. You can recheck them when confirm. Secret station section custom level button. And tick filter is disabled. To advance section, check box use software instead rendering apply this.
When you change something must click on apply then your way out of other pages.
