masud_102
Posted on - 09/26/2011
I am using HTC touch 3232. IÂ downloaded UCB browser for my phone and installed that. But i only can use that browser for 5-10 minute after that it automatically closed down and all the services (like upload download) stops automatically. Any idea how do solve that problem. Is there any better Phone browser for HTC?
Why do my UCB browser closed down automatically??
Well UCB Browser crashes due to pre fetching the page.
For your HTC touch 3232 I would suggest you to use Opera Mini 5.0. It is faster and also quickest. Various new features of Opera as well as its most advanced download manager for mobile phone is all I can say the best for you in comparison to UCB Web Browser for your HTC 3232.
You can download a full featured Opera Browser for your mobile through PC here,
If you want to download it through your cell phone then here's the link-
You may have installed a UCB browser version that is not compatible to the operating system that is being used by your phone, and therefore you will need to get the right version and install it.
But since you are able to use the browser for some time, then the problem may also not be because of compatibility, but with the size of the browser.
The browser may be large and therefore taking a lot of memory space when being executed, and that is why it will automatically close after some few minutes so as to prevent the computer from running out memory. You will therefore need to get a considerably smaller browser that will not consume the memory on your phone.
Clair Charles
