maddona
30 points
Posted on - 07/19/2011
I have a Nokia mobile phone and I can easily use the internet with this mobile phone. It's model is 1680. When I install Nimbuzz, it shows a message like this, "your memory is full and do not install." But Nimbuzz is downloaded in my phone.
So tell me what happened there.
alexx
5 points
Why do not I Nimbuzz install in my mobile phone?
First of all, you should try to check some other phone of the same model as yours. If there is no problem, then it means there is a problem with your phone. So check your phone memory or card.
If there is a card then check, card memory whether it is okay or if there is any bad sector or virus.
If not, then try to download nimbuzz from some other mobile or direct PC is more suitable.
You can download it from the link above then transfer it to your mobile.
Hello! It seems your phone's memory is full. Try the alternative of deleting some not so important files, then download Nimbuzz for Nokia again and install it.
Just make sure this time the date settings are correct before you install Nimbuzz, else it won't continue due to system synchronization.
Hi Maddona,
I think your mobile phone memory is full. Please delete some data or alternative memory card. I's very important to download Nimbuzz on it and make sure of the time and date settings before you install Nimbuzz.
You can also download it from this site: http//www.getjar.com and then transfer it, to your mobile. I think it will work.
