Why do not use a Structured Query Language (SQL) and / or queries from X to Resource Description Framework (RDF) files query? Why need to enhance a new query of words? And how fast could I work the task item into the emails?
Why not use a Structured Query Language (SQL)?
As far as the versions before version 9 are concerned RDF does not support MS SQL native client. Therefore the meta schema mapping has to be used to perform the function. There are many opensource and third party softwares that can be used for this purpose. One of them is known as squirrel rdf and is open source.
you can also use virtuoso's rdf to sql mapping technology which is very familiar nowadays to create rdf views of sql data.
for further information on how to use rdf along with xml and other related procedures please follow the following link:
https://www.w3.org/wiki/RdfAndSql
Janet
