I have a 32 GB LTE Galaxy Note N7000 with Wi-Fi 802.11 a/b/g/n, dual-band, DLNA, Wi-Fi Direct, Wi-Fi hotspot. I've been having wifi disconnect after a few minutes everytime since updating to Android 4.1 Jelly Bean. Why does Galaxy Note wifi disconnect often?
It is also known as Samsung I9220 and Samsung GT-N7000. The Samsung Galaxy Note N7000 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using the GSM, HSPA, and LTE technologies. It was announced on September 2011 and released a month after, October 2011, measuring 146.9 x 83 x 9.7 millimeters and weighing 178 grams. It uses mini-SIM card and includes an S Pen stylus.
It has Super AMOLED capacitive touchscreen display with 16M colors at 800 x 1280 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass featuring TouchWiz UI 4.0. It runs on Android 2.3.5 Gingerbread upgradable to Android 4.1.2 Jelly Bean powered by Exynos chipset, 1.4 GHz Dual-Core ARM Cortex-A9 processor, and Mali-400 GPU. It supports microSD expandable up to 64 GB.
It runs on 1 GB RAM with internal storage available in 16 GB and 32 GB capacities. The primary camera supports 8 megapixels at 3264 x 2448 pixels screen resolution with LED flash and autofocus featuring geo-tagging, face and smile detection, and touch focus. It supports 1080p video recording at 24 to 30 fps. The secondary camera supports 2 megapixels.
It has Bluetooth 3.0 with A2DP and EDR support; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; GPS with A-GPS and GLONASS support; NFC; and microUSB 2.0 MHL TV-out with USB Host support. It has built-in accelerometer, proximity, compass, barometer, and gyro sensors. The pre-installed web browser supports HTML5 with Adobe Flash support. Java is supported.
It runs on Li-Ion 2500 mAh battery with standby time up to 960 hours on 2G and 820 hours on 3G. Talk time is up to 26 hours 10 minutes on 2G and 13 hours 30 minutes on 3G. Now, if your phone frequently disconnects from the internet, try checking your distance from your Wi-Fi router.
Since Smartphones rely on wireless connection to connect to the internet either via Wi-Fi or data connection, the stability of your connection depends on the strength of the signal you are receiving. If you are connecting to the internet via Wi-Fi, make sure you are not too far from the router.
As you go farther and farther from your router, the Wi-Fi signal you are receiving gets thinner and thinner and this affects the speed and reliability of your connection. To fix the problem of frequent disconnection, move a little closer to your Wi-Fi router to improve the Wi-Fi signal reception.
1....
