Why Does Internet Explorer Crash When Opening?
One out of 2 times, Internet Explorer crashes when opening. I don’t use it very often, but it is required for some websites and it is frustrating when it crashes. Please help.
If Internet Explorer is crashing continuously, then the problem must be due to damaged files or missing files.First, try restarting your system as this is the standard solution to most of the problems. If the issue persists, then check if your Internet Explorer is up to date and if it is not, update it. After this, turn off and turn on Internet Explorer. This should solve your problem. If this does not work, turn off the add-ons if any. Now lastly, reset the Internet Explorer settings and this must solve the issue.
