Hi guys,
I have a laptop with windows 7 in it. The problem is when ever I shut down and turn on again on laptop the windows defender turns off..But why???Â
I'm really irritate with this problem I turned it on again but still next time when I open my laptop it's turned off.Please elp me with this issue.
points
Why does my Windows defender turns off automatically?help
Windows Defender is a default protection software that comes with Windows while installing the operating system. If you have installed any third party protection software, you are making the use of the external software that disables Windows Defender.
You have nothing to worry about it if you have installed any antivirus in your PC. If you didn’t, check your PC for any virus. You can use Norton Power Eraser that uses aggressive mode to detect viruses.
Also, you can use any good antivirus program, for example, Norton, Kaspersky, Avast, MSE etc. for your security solution. They will disable the built-in Windows Defender and make their advanced defending engine work around your PC and provide the best security.
