Why doesn’t open an Acronis format file ?
I have an Acronis format file on my PC. When I tried to open it, It didn't open. I am told to go online. I have tried but can't. Can anyone solve this problem ?
Thanks
Thanks
Hi Rachel,
You didn’t mention about the specific error message, It was better to solve the problem. Though you don’t have to worry. First of all, just check your PC for invalid registry entries and other speed issues. If there is any problem with the registry entries, then try to fix it first. Now try to open the file.
Hi, Friend,
You will have to specify which software should be used to open that file.
Right click on the file then choose open with then browse to where the software of choice is located and select.
You can also do this by opening the software then clicking the file option usually on the top left then choose open file and navigate to your file.
Amos Marie
Notifications
