Why doesn’t my computer detect any USB sticks?
Hi everyone,
I have problem, my computer cannot detect any USB sticks, at first I though it is my USB,
Hi everyone,
Solution 1
Reinstall the USB 2.0 driver for windows XP. It is the driver use for reading USB in the computer. Of course almost all of the operating system that Microsoft has starting from XP up to the latest.
Solution 2
Reinstall the chip set of your computer motherboard, it might be the cause of the problem.
Solution 3 (least priority)
Try operating system repair or try reformatting though it is the least priority but it might be able to fix it. Also try changing the power supply unit this can also be a cause because it is not giving enough power to the USBs the you inserted.
If your using windows xp
1.left click start
2.right click my computer
3.left click properties
4.select hardware tab and left click device manager
5. click plus sign beside Universal Serial Bus Controllers
6. check if theres an exclamation sign under Universal Serial Bus Controllers
7. right click exclamation sign
8. left click uninstall
9. right click uninversal serial bus controller
10. right click scan for hardware changes
