Hi Experts,
I am having dolphin 7 on my desktop. It is embedded to my windows os. I cannot guess why dolphin 7 embed failed. I tried to recover the software by using many options but it failed. I need step by step guidance to recover this.
Aimeemorgann
Why dolphin 7 embed failed ?
If your Dolphin 7 software is already not working properly then try doing another clean installation of the program to fix any corrupted files that may have developed from the time it was first installed. But before doing this, be sure that you still have its installer.
Uninstall the program then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use disk utility applications like Norton Utilities, PC Tools Performance Toolkit, or Norton SystemWorks. Install the application again then see if this works.
Or you may simply download the installer again from BOONEX — Dolphin 7.1. But don’t forget that this version that you are going to download is not a free version. In other words, you have to pay for it.
