As EMC Replistor 5is a data replication software and it works on both LAN and WAN. It also supports remote installation. But I have some problems. Whenever I make some changes in the source computer like editing file or replicating data then target computer is not updated accordingly. I think it is due to synchronization of data but not sure. Any solution please.
Why EMC REPLISTOR 5 is not working on LAN?
Hello Stephen Vanness,
     I think that you have some LAN problem or network problem. If you are connecting with LAN then you have to see that LAN wire there must be a problem in it . But if you are using wireless system them i think that you have not connected the computer with a home group or a specific network. Try this if after that you still get any thing then you have to reinstall the software and try to install by clicking Open as Administrator that will install the components completely.
