Why express talk for lion does not transmit audio?
Hi. Now mostly softwares are used for online video as well as audio chat. I use express talk for lion as it is easy to use. But now it is creating problems. When I connect and chat with friends, web cam transmits video but audio is not transmitting. I checked mic as well as speaker but no result. Tell me what the problem with express talk?
Answered By 10 points N/A #142101
Use different software that will give you both the best result in audio or video, but if the you want to use the current software then check your system MIC port may be problem with your system MIC, if  it work correctly then reinstall the drivers again, some time it will happen when system corrupt the files, If the drivers work correctly then repair your windows. The problem will be solved.
