Why I can’t print from Google chrome.
I installed Google chrome 24.0.1312.56 version on my PC. Trying to print directly from Chrome browser. But can't. Why? Have I done any mistake with chrome print management ?
I think that there is some mistake with print management in Google Chrome, there are a lot of with same issue.
I will recommended you a few things that you can do. Try to clear your cache and cookies, disable your extensions and see that you are not blocking 3rd party cookies (go in settings, then advanced settings and clear the content settings).
If that does not work try pressing ctrl+shift+P keys if you use Windows OS and the printing should start.
Williamson Mellisa
