Ava White
10 points
Posted on - 11/02/2011
Hi Team,
I got browser error message when attempt to download clusterware software. After click error I got ‘null’ is null or not an object.
I got same problem again and again after trying in various browsers and PC’s.
Thanks in Advance
Why i got browser error message ?
If you already used different browsers and different computers to download the same file on that website, there is a problem with the website's link.
Maybe the url of the download link has a text accidentally added to the code that’s why it can’t be downloaded. Or maybe there is an error in the java script that handles the download link.
Try sending an inquiry to the website’s admin so they will be informed about the error in their download link. Try searching for the stuff that you want to download in other websites.
I’m sure you can find it in other domains. There’s no use of trying to download it every now and then. The result will still be the same.
Trevor
Sometimes links are protected and it is not open for public. There are some sites displaying the link or the download link but they do not allow intruders to download the link contents.
You need to log-on on their site so that you can download particular software or file. You need to inform the site admin or ask for the assistance so that you can download the file.
Another solution for this is tried to look for other site that offering download for the software you are downloading. Google search can give you results for these queries just have a little patience searching for the right site.
Thanks techyv experts for the information. It make sense to me now. Thank you, thank you
