Hello TechyV,
Please explain why I would need to use UMove if I can create a snapshot of AD on Windows Server 2008. Is there a way that I can be informed of AD database corruption? I need to schedule a daily backup of Active Directory.
How would I do that?Â
Please help me.
Why I would need to use UMove?
Hi there,
UMove is the only software utility that has been availed to help in Microsoft Active Directory database management. It can enable you to move, recover, duplicate or copy the database for recovery or back up or testing purposes. You can order to purchase it online & is compatible with most Windows platforms available today. It comes with a number of advantages ;
It can make daily perfect snapshots or duplicate the Active Directory database, even from a dead PC or a non bootable PC. It allows you to move the active directory database to new PC hardware quickly & easily.
You can schedule daily regular backups of your directory without much problems. Their information backed up is all that can be needed in order to restore an Active Directory.
You can be able to transfer your domain control to a faster PC if need be.
You can transfer your active directory to an isolated virtual machine for testing purposes.
Here is a link that will help you understand more and a screenshot snap of how the UMove page looks like.
https://u-tools.com/u-move
