Why important to remove the free avast toolbar
Hello MDÂ RAVIULÂ ALAM,Â
If you would like to completely remove the toolbar from your computer you may uninstall it from Control Panel.
If you would like to just disable it from your browser, here's what you can do:
For Internet Explorer
For Firefox
For Google Chrome
Apparently there is no such Avast toolbar you are referring. The most reliable source is Avast forum. There is an already a thread about this.Â
However I give you a solution.
To stop avast toolbar firstly click the view button then disables the toolbar name. If you want to uninstall this please go to start menu.Â
Then you are going to control menu and click uninstall program. After that please find your avast toolbar and click to uninstall .
Thank's.
