Why Internet Explorer Stops Working?
Recently I encountered an error on my internet explorer. It closes by saying that is has stoppedworking.Why doesinternet explorer stop working? How do I remove this error?
The executable file for internet explorer must be conflicting with other applications. This might happen due to some misconfigured add-ons or extensions. Try are several solutions for this problem.First, try uninstalling unwanted toolbars from IE. If you still get the error, follow the steps below.
Usually, that happens out of accident. It’s like a sudden error just hit the application that triggered itself to close. This is actually normal and can happen in any applications not just Microsoft Internet Explorer. If your browser suddenly closes then displaying that error on your screen, just launch it again. It is actually not a major problem. See if the problem happens again after restarting.
If the problem re-occurs, try updating Microsoft Internet Explorer if you still have a supported operating system. If you cannot update, just download the installer manually and install it to upgrade your browser. For version 8, download Microsoft Internet Explorer 8. For version 9, download Microsoft Internet Explorer 9. For version 10, download Microsoft Internet Explorer 10.
If the problem continues, just use a different browser. You can try Mozilla Firefox, Google Chrome, and Opera.
