Why Is Microsoft Operations Manager Important?
I was cleaning my system, and I encountered with the Microsoft operations manager. I want to know its purpose and importance?
Microsoft operations manager helps you in monitoring, security checks, capability, compatibility, events occurring with Microsoft and its performance in systems. It helps the administrators and developers to keep a check over the highs and lows of all the products of Microsoft and check whether they are working properly or not.
This helps in checking if their product is compatible, easy to use and more importantly not creating any issues with the users. Sometimes, due to some technical faults in the development of particular software, the software starts encountering so many errors that it cannot be used properly. This is why Microsoft operations manager is important.
MOM or Microsoft Operations Manager is a scalable and flexible rules-based operations management solution for distributed environments. It provides event-driven operations monitoring, security policy enforcement, performance tracking, and auditing capability. The MOM SDK provides administrators and developers information about customizing and extending MOM. The MOM SDK allows you to develop MOM applications using any programming language supported by Microsoft .NET Framework.
You can create MOM response scripts using any ActiveX scripting language like JScript and VBScript. Custom MOM reports are developed using Microsoft SQL Server 2000 Reporting Services. Data access uses any technology compatible with Microsoft SQL Server.
