Why Is The 0x800703e3 Windows 10 Error Occurs?
Hello, experts. I am getting the 0x800703e3 Windows 10 error while updating the OS on my PC. Please help me with a quick solution to resolve it. Thank you.
Hello. The 0x800703e3 Windows 10 caused due to the misconfiguration of the system files or wrong entries of registry keys. Follow the methods to resolve it.
Method 1:
Update Windows manually
• Hold the win + I keys; it opens settings.
• Go to Update& Security.
• Next, click on view installed updates.
• Check for failed updates and install them manually.
• Restart your PC.
Method 2:
Using Media creation tool
• Log on to your computer as an admin.
• Go to the control panel.
• Go to the file exploration options and click on it.
• In the next window, go to the View tab and enable show hidden files and folders option.
• Click on ok and close the window.
• Next, hold the win key + E to open file explorer.
• Navigate to this PC, and open C Drive.
• Navigate to $Windows.~ BT and $Windows.~ WS and delete them.
• After this, you can use a bootable USB without getting an error.
