I really don’t understand, whenever the new update of internet security launches by Kaspersky. Then, Kaspersky will not update its internet security automatically, so, if it doesn’t update automatically how can we do manually?
Why Kaspersky Will Not Update Internet Security Automatically, Whenever A New Update Releases?
This is quite a normal issue faced by many people around us. The problem is not related to Kaspersky product. It is because some of the settings we made to the system or software. If not few of the incompatible Software present on the system. Normally, why Kaspersky will not update internet security automatically is due to following reasons and we can fix manually.
1) Check the time and date on the computer. If it is not correct, then set it to current time and date.
2) Check the internet connection whether it is working or not.
3) Reset the settings of Internet Explorer.
4) Remove third-party firewall or anti-virus software if any.
5) Look after the availability of Kaspersky Lab update servers.
6) Scan the system to trace any virus is present or not with the virus-removal tools.
7) If none of the above solves the problem reinstall the product.
