I have fall into my keyboard shortcut problem. It is OK from starting my computer for one and half hour.
Then I face this problem.
When I press I or E, all the program running is shown in the status bar
When I press L, my system goes for Log off.
Please Help me.
raofu
Why keyboard problem in shortcut?
Well, it is the 60% problem with your current keyboard, replace it with a new one or some which is good in condition, it is up to you.
If the problem persists then try to consult to a hardware specialist for better solution.
This problems causes sometimes due to some viruses and malware files so you should have to scan your completely totally by a powerful and registered anti virus software such as AVG or Kaspersky, the snapshots of Kaspersky is given below which may help you,
Keyboard shortcuts are used to open an application, save changes, to interact with the computer and to save time and effort by the use of 2-3 or more keys combinations.
Here in Microsoft website has the complete list of shortcut keys, combination using mouse, keyboard and some function keys.
Looking at the post, by pressing I, E, L then the computer will display all the running windows and or it log-off the computer is strange. Pressing these characters will only print the letter's I, E, L in the text provided.
As I analyzed further, the possible issue with this is virus/Trojan infections. A corrupted operating system and a bad keyboard.
Considering the possibilities, you may need to scan the anti-virus software to check for infections. Re-installing the OS does help to fix corrupted software. Lastly, keyboard replacement does also help.
