Why Mac over pc where every Mac is a pc?
Here are the very reasons why everyone must choose a mac:
Designed to last.
A Mac is designed for a long, productive life. Apple designers and engineers spend countless hours ensuring that each Mac is precisely built — inside and out.
From the down-to-the-micron fit of each internal component to the finish of the enclosure, every detail matters.
Born to perform.
To make a better computer, only quality components and materials will do. That’s why every Mac contains storage technology, memory, a graphics processor, even a power supply specifically chosen to give you the best performance possible.
Charge today and five years from today.
Getting a few hours of battery life from a notebook is good. But for a Mac, good isn’t good enough. That means you can power through a day of work or a day of classes without stopping to find the nearest outlet.
It’s packed with innovative features.
A Multi-Touch track pad, a wireless keyboard and wireless mouse, and a built-in camera — just to name a few. On a Mac, innovation extends to features you might not expect.
Now tell me Mac or PC?
Hi Josella,
A mac is easy to use, efficient, and it has a very friendly user interface. It is made with a lot of simplicity. Macs are less vulnerable to viruses compared to the Windows counterpart.
It also supports more than one operating system to run on it at a time hence being so convenient for organizations that use a number of operating systems in doing tasks.
Mac has the Apple store, a place where you can take your Mac if anything goes wrong, and there's a good chance it will get fixed as opposed to Windows.
Mac has very compatible products, like the one below can be used as a computer apart from being just a phone.
The products of mac work well with each other, they do not have compatibility issues as you will find in Windows.
Hope this helps.
Lee Hung.
It's now been two years since I switched from PC to Mac. However I still use Windows 8 but why I love Mac is because:
