anam277
Posted on - 03/07/2012
I want to know about the recent problem i faced while deleting history from my mozilla firefox.What is the reason behind it?and how can i avoid this in futuure.Earlier there was no such problem.plz help.
Why mozilla got corrupted while deleting history
I’m sorry but you did not point out what kind of problem you did encounter in Mozilla when you cleared its history.
But anyway, if you did encounter such an error, just try uninstalling and then reinstall back Mozilla to fix any corrupted files in the installation and to restore its settings back to default including some that you might have customized.
You may also try checking your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, PC Tools Performance Toolkit, or Norton SystemWorks.
Any errors present in the hard drive’s file system may cause problems to applications. And can also make some installations to go wrong that leads to an incomplete product installation.
