This problematic pestered me for a while at this instant. I cannot install the latest version of flash player for IE8. I need previously run the flash player un-installer and tried reinstalling the situation manually, but I get the like message. Flash Player is also not listed in the "Add or Remove Programs" list. Flash player works through situation hall extra browsers, but IE8 for some rebellion. I do not want near use other browsers equally I am quite station content through situations IE.
Why my activex control for flash player could not be registered
Flash hequally remained updated (yet again) toward 11.1.102.55, while I don't think that would be the object of your problem.
I'm not sure I recognize pardon you're sighted when you effort toward upgrade Flash in Internet Explorer (which is pardon I consent you're trying toward do?). In my Add/Remove list I need an ticket for the Active X version (because although I don't use IE, I realm the situation up to date) and an entry like this for the version cequallyt-off by my Opera and Firefox browsers "Adobe Flash Player 11 Plugin"
You had to wequallyte the Google toolbar (unless you wanted the situation) and then accept various options to whole the install. At this prompt you get a 741 KB .exe file which, when double clicked, finalizes the installation of the full 3.62 MB package, although, Uncertainty I remember correctly, you still want toward approving w the state he the successively of Active X controls etc.
Uncertainty you try the installation over, make a note of the full text of any error messages you get and post them here. Somebody extra at this instantledgeable than me possibly able to help.
