Why my ASUS driver can’t be installed?
I use an ASUS laptop and I have a problem while installing a driver for my WLAN on my laptop. What may be the problem?
Please suggest some solutions for this problem.
Not an ASUS laptop only, every laptop may have some problem occurred by installing the driver. There may be different type of problem but which is occurred in your laptop when you try to install your WLAN.
Which type of alert you have gotten? Which model of ASUS laptop and you are using? Which operating system is present in your laptop? This is so important. I think this is time for moderation so you can use Bluetooth system instead of WLAN. I think you can tell your question again with detail.
Besides you can contact asus support center website to get the proper solution.
Hey Matth Santos!
There is a possibility that the driver you are installing is not compatible with your laptop, that's why you are facing this problem.
First of all you need to know what the product number of your laptop is. You can check under the laptop. After that open the ASUS website and enter there the product number of your laptop. You will found there those drivers, which are compatible to your laptop.
Secondly, there are many software which download the drivers automatically. For example Driver genius is software that can automatically download the latest drivers for your laptop.
Thanks
good evening to all !
I have an asus laptop too and now i can install anything what i want to install and its all because of your solutions experts, and to techyv this site.
Thank you all… experts and techyv.
More power to all
Notifications
