Why is my CD- ROM selecting disks
How do I play other disk format on my laptop CD – ROM? My laptop disk player is always playing CD and DVD RW+ format while other format is not seen from the drive. The manufacturer manual says the disk player can play all dvd format, but that is not he since I bought the laptop. I initially believe it was caused by the disk player dirty lens, but after repeated cleaning there is no notable difference.
