Why is my Compaq running Divx player way too slow ?
Hello you guys i have a weird problem on my Compaq Presario Notebook Specs : Model CQ61 15.6" 2.0ghz 4gb ram 250gb , the notebook is not slow when i surf the internet but when i try to open a movie with my divx player the computer freezes for about 2 second then start buffering too slow i am having this issue per day and it is really bugging me. Even when i play a pay per view video on the internet using the divx player technology it still buffers too slow , i know that Compaq is old but i really like my notebook ..
Best Answer by DwayneJames36
Answered By 0 points N/A #162672
Hi, Hossam
I suggest you to follow these trouble shooting steps to fix the issue with the DivX player on your laptop.
>>Please check whether your graphics driver is up to date.
>>Try re-installing DivX player on your computer.
>>If that does not fix the issue, try resetting your internet settings and perform a system restore.
>>Download and install the latest version of DivX player and check if the issue is fixed.
>>If the above steps do not help to fix the issue, you can switch to another player.
Thanks and regards
Skarbos Jay.
Answered By 0 points N/A #162673
Hi and Good Day!
Regarding on your question, it’s not natural that your laptop freezes and too slow while surfing the internet.
Here are my suggestions to your said problem.
v  Make sure that you have the latest version DivX Player, and determine if it is compatible on your web-browser.
v  If yes, try to look that your graphic card is up-to-date and compatible on your computer system.
v  If does not work, change your streaming technology.
v  If you do not want to change your streaming player, I suggest either look for a computer technician on your area, or go to the service center of the manufacturer of your laptop.
I hoped I helped you.
