Yonisitbon
220 points
Posted on - 05/22/2011
My name is Yoni and I got stuck with a really bad problem. I play so many online games, more than five, and I got problem. I have a Windows Vista, and every time I login a game, my computer just gets stuck. I don't know why, maybe because I got many files on my computer or is it because of the Windows Vista? I am trying to ask myself that, and I really want to fix that problem.
Another problem I have, sometimes I can login into some games, but I got really big internet problems. Because my computer doesn't really get the internet so good as I use a WiFi connection, if someone can help, I would be more than happy. I bought this computer at 2009, it was with really good speed at the store, this problem started 2 weeks ago.
I think personally that Windows Vista isn't so good, all my friends told me to not buy Vista. But I still did, because it's a really looking good laptop. I really want to play my games as soon as possible. So what do you say? Should I buy a new computer or fix it? And if yes, could you tell me how to fix it, I don't really know how. At the store they told me one year over, so I got no insurance on this computer.
Sometimes I can't even can login to the internet, which is really making me mad. Plus, when I restart the computer, it make me to press "Start windows normally" or "Safe mode". Of course I press the start normally, because when I press safe mode it just restarts. Which is really make me mad. So, I hope somebody got the answer I am looking for, as soon as possible answer please. Thanks.
ktech
5 points
Why is my computer so slow?
Hi Yonisitbon,
Here could be several reasons why your computer slows down or hangs up. One of them will be viruses and/or other mal wares like a worm or it may just be the disk space in your PC. With regards to Windows Vista, well, a good number of people actually prefer Windows XP or Windows 7 over Windows Vista. If you have the money, then feel free to buy another one but if your PC’s specs are good then, you could always change your Operating system and save a lot of money.
Here are 10 things you can do to improve the performance of your Vista.
1. Virtual Memory – If your PC doesn’t have enough memory that it needs to perform, either Windows or the program you are running or both will stop running. Windows uses Virtual memory to help in running programs. Increasing the Virtual Memory helps your computer store more information for processing.
Click Start>Control Panel
Open System
Click on “Advanced system settings” at the left pane. If prompted, click “Allow” to proceed.
In System Properties window, go to the “Advanced” tab
Under “Performance”, click “Settings”
Performance Options dialog box will pop up, go to the “Advanced” tab
Under “Virtual Memory”, click “Change”
Remove the check mark on “Automatically manage paging file size for all drives”
Choose the Drive where you want your Virtual Disk to be at.
Select “Custom Size” and put in your desired size.
Press Set
Restart
Note: The recommended size is 2-3 times your physical RAM size. However, it still depends on your normal usage. In your case it would be better if it’s bigger than 3 times the RAM size.
2. Defrag your PC – A good analogy for fragmentation would be the filing cabinet. Imagine you had your employees’ files in different manila folders scattered amongst 7 filing cabinets. You’d have to go from cabinet to cabinet to find the folder that you need. It’s the same way with your computer. This occurs normally since you use the computer for different processes all at the same time. Defragging your computer arranges the manila folders in the filing cabinet according to frequency of use, putting the ones which are always used in front.
Click Start
Type “defrag” in the search box and press Enter
3. Viruses and other Malware – There could be viruses doing some damage in your PC. If not, then it could be a Trojan, a worm, spyware or other malicious software that is wreaking havoc in your PC. These malicious programs are known to use huge memory resources and destroy system files. So make sure you have a good antivirus or anti malware securing your PC.
4. Start Up – When logging on to Windows, there are Programs which are programmed to run right away too. If there are many programs trying to run altogether, this would cause the PC to slow down. You can prevent these programs from running since you don’t really need most of them to run at start up.
To disable the programs to run at start up:
Click Start
In the Search bar, type msconfig and press Enter.
Go to the Startup tab
Remove the check on any Startup Item you don’t want.
5. Remove a feature – Vista has all kinds of feature and applications that are needed for whatever kind of work you will do on your PC. However, for home users, you don’t really need most of them.
To turn off a feature:
Click Start
Go to Control Panel
Click Uninstall a Program
In the “Uninstall or Change a Program” click the “Turn Windows Features On or Off”
Uncheck any feature you don't need running
If you hover the mouse over a feature, a tool tip tells you what it is.
For gaming, You can remove everything else except:
The games
XPS Viewer (under .NET Framework 3.0)
Remote Differential Compression
Windows Ultimate Extras
However, still check if you might need other features if you use your PC other than games.
6. Windows Services – Services are programs that are continuously running in the background of Windows. They do different tasks that Windows needs to be done. There are a lot of these services and they can also use a lot of memory/resources. However, not all of these Services are actually needed and can be turned off without any problems. Follow these steps on how to turn off some services:
Click Start
In the Search bar, type “msconfig” and press Enter
Here are some services that could be disabled in a gaming computer:
DFS Replication
Computer Browser
Distributed Link Tracking Client
IKE and AuthIP IPsec Keying Modules
IP Helper
IPsec Policy Agent
KtmRm for Distributed Transaction Coordinator
Offline Files
Remote Registry
Secondary Logon
Security Center (Use caution if you disable security services!)
SSDP Discovery
Tablet PC Input Service
Terminal Services
Windows Defender (Ditto the above warning!)
Windows Error Reporting Service
7. Cannot connect to the Internet? – There can be several reasons why you could not connect to the internet. Check your:
Modem
Router
LAN Cable
Are you using a Proxy Server?
Ask your ISP
Check Firewall of Antivirus.
Check the Firewall settings in Vista:
Click Start.
Go to Control Panel
Click “Security”, and choose “Security Center”.
Click the “Windows Firewall” link on the left side and choose “Change Settings”.
Go to the “Exceptions” tab
Click Add Program button and select the program (or Browse to locate the program), and click OK.
8. Sidebar – If you can live without the Sidebar, then just remove it. Even though it has a small task, if still uses memory resources which can be used to other things. Why not just remove it to help your PC have a little boost.
To disable the sidebar:
Right click on the sidebar or sidebar the icon, select Properties
Remove the check from “Start Sidebar when Windows starts”
Then right-click on the icon, and choose Exit to close the sidebar:
9. Disable Search Indexing – Although the search option is good, it still hogs a lot of resources. The Windows Indexing Service is always running in the background and can slow down your PC a little. Turning this feature off will make searching for files and folders slower –who uses windows search feature everyday anyway?
To disable the Windows Indexing Service:
Right click the C: drive and select Properties
Remove the check mark of "Allow Indexing Service to index this disk for fast file searching"
Hit OK.
10. Install a new OS – If you’re still not satisfied after having done all of this and more, you can always just install a new Operating System.
Hopefully, your PC is running much faster now. Good Luck!
realtech
Speed up your computer by:
— Cleaning system junk.
— Optimizing computer services.
— Optimizing internet.
— Repairing registry.
— Defragging registry.
— Clearing browsers junk.
Do these things with some secure tool such as Intel Software Partner Reginout.
