Why is my computer suddenly so slow now
Why is my computer suddenly so slow? And also FPS on every game is very low. Can anybody help me to solve this problem? How can I resolve this?
I think, the graphics card and power supply are OK.
And the cpu is running way too hot- at 74.5C.
Make the cpu much cooler by following these steps:
First, blow the case out , and especially coolers, filters and fans.
And if it doesn't get its temperatures down to 50C gaming, 35C idle then-
Then, Reseat the cooler of cpu -Remove the cooler and fan.
Also, use the isopropyl alcohol for cleaning the former thermal paste from the bottom of your cooler and top of your cpu.
Also, put a drop of thermal paste of Artcic Silver 5 on your cpu's center. Then put your cooler back. And reconnect your fan.
Hopefully, this answer is helpful, easier and clearer steps to fix the problem.
