Hi everyone! I have a Dell inspiron laptop, and from some time ago it is continuously failing to connect to a network. Please provide any reasons for me to work on to find out why my Dell won’t connect to internet even if it sees the network?
Why my Dell won’t connect to internet?
If your PC was connecting to the network before you have made any changes, then you should look up to one of these problems that may have caused the frequent connection failures:
1. Device Driver: Make sure that you have the Device Driver downloaded for the computer’s wireless adapter.
2. Wireless Adapter: Check that your wireless adapter is enabled, or press the Function F2 key to enable it.
3. Encryption Key: Check that you have correct encryption key entered to connect the router to your device.
4. System Files: You may have a corrupted system file.to resolve this issue; try to scan the Windows system.
