Hi guys,
I want to know why my Dropbox is having problem to move folders from one destination to another. This is the first time I'm having this problem in Dropbox. I even checked that my internet connection is in workig state but still I have the same problem. Please tell me what to do now. Thanks in advance.
Why my Dropbox does not move folders?
Hello Joseph,
You can try the following options for moving your folders:
1)Â Â Right Click on your Dropbox icon
2)Â Â Go to Preferences
3)  Go to Advanced  tab
4)Â Â You can give the path here where you want to move
5)Â Â Click OK.
Hope this will work and it will move your folders as you want.
Hello, How are you? You can move your folder using the Dropbox desktop application. So, follow the steps :
Step 1 : Search and click on the Dropbox icon from the system tray.
Step 2 : Secondly, click on the gear icon and select Preferences from the menu option/bar.
Step 3 : Then click on Account tab.
Step 4 : Move the Dropbox folder location by selecting move.
Step 5 : Select the new location for your Dropbox folder.
Maintaining the above mentioned steps you can solve your problem.
Moreen Jamnelly.
